** TRYX FLOVA F50 CASE **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Gang
We are finally able to announce immediate availability of the brand new FLOVA F50 case from TRYX
The FLOVA is a Mid Tower case that features a contemporary look without resorting to festooning itself with wooden panels. :o
The FLOVA stands out from the crowd by achieving a smart aesthetic using a premium fabric mesh at the front and lower side panel area that is easy to remove for cleaning and maintenance.
This is a flexible chassis that has ATX / Micro-ATX / Mini-ITX and Back Connect Motherboard Support as well as being able to accommodate the largest and most powerful GPUs available today (420mm Max)
The Unique selling point of the FLOVA F50 is the TCF (TRYX Cross-Flow) fan that allows for an low profile and quiet intake area at the front of the case. The TCF Crossflow fan is designed to deliver air directly to heat sources throughout the main chamber of the case whilst remaining quiet. The fan has an internal control switch that allows you to select an appropriate fan speed
FLOVA F50 is available in Black, White and Pink and is shipping right now :cool:
