TS RemoteApp - defaulting domain?
7 Jun 2003
Gloucestershire
Hi,
I've got RemoteApp setup, i can access it internally and externally quite happily, load apps and use them so on and so forth...
Problem is when loading an app it asks you for your login details, at this point if you are external to our network you have to put domain\username opposed to simply entering your username and password.
Is there a way to either A. Automatically default it to a particular domain name or B. Enable some form of single sign on where by i only need to login to remoteapp and from there it uses the details i logged in with originally?
