TS & SQL Server - Hardware Opinion
20 Oct 2002
Space, the final frontier
Currently trying to sort out a new TS and SQL server, this is the current spec which hosts internally 50 users
Dual Xeon (Server is about 6yrs old), 4GB, 2x 74GB SCSI (7200rpm) Raid 1 running Windows 2000 Server and SQL 2000
It also runs TS for about 50 users
Now it's very slow, falls over and the main business app running on it falls over on a regular basis, now this is the spec they have been recommend for the upgrade and also to grow another 50 users over the next five years.
TS Box - Xeon 5320, 3GB, 2x146GB 10k SAS Raid 1 on 128mb controller, redundant PSU, 3YRs hardware support, Windows 2003 Standard R2
SQL Box - Dual Xeon 5320, 8GB, 7x 146GB SAS 10k, 2xRaid1, 5xRaid5, Redundant PSU, Windows 2003 Server X64 R2 STD, Single SQL 2005 Standard X64 CPU License
Would this be enough for 50-100 users for the next five years? I had spec'd something quite different, but they want the cheapest option
Thanks
That spec appears to be dire.... firstly it's a single physical processor license, therefore get as many cores on it as you can.
Secondly the drive spec is awful, a simple (read consolidated) array config would be something like 2x10k disks in a raid 1 array for the OS, raid 5 15k array for the database (the amount of spindles depends on your IO requirements but remember, raid 5 is n+1), 2xsata disks in a raid 1 array for the logs and then another raid 5 array for the backups..... If you were taking it more seriously you'd also mount tempdb on a raid 1 array or some such, seperate from the main database.
Finally, the memory is quite important, if it's feasible, buy as much memory as you can so that the entire database can sit in memory. Especially on a 64bit host....
With that much memory you might get paging and if that happens, with that array, you'll get a performance hit.
As before, quad core (get two?), as much memory as you can afford and seperate your apps from your OS array.
Well this is what I thought, but hey the customer is always right (or not as the case may be)
Here is what I spec'd
TS: Dual Quad Core E5340, 8GB, 4x73GB 15k SAS, Raid 10 with 1x73GB Hotspare on 256mb raid controller with BBU, SAS Controller with external ports, with LTO-4 Backup for both TS and SQL box (and future Exchange 2007 Box), Windows 2003 Server Standard X64, Redundant PSUs etc..
SQL: Quad Core X5450, 8GB, 2x 146GB 15k SAS Raid 1, 6x 146GB Raid 10, 1x146GB SAS Global HS, Redundant PSUs, Windows 2003 Standars X64 and SQL 2005 Standard X64 (Single CPU Licence)
How does that sound?
The 5320 CPU they spec'd is a Quad 1.86Ghz, 1066 with 2x4mb where as the one's im looking to use are 2.66Ghz with 1333 and 2x6mb and the SQL is a 3Ghz, 1333 2x6mb
Edit: They have also suggested, that as they dont want to pay for TS licensing, they want to use their old box for TS instead of the new server so they didnt have to spend more lol
for the TS box you only really need 1 Quad core. Every TS box i have used disk and memory are the main bottlenecks.
But then again for what they cost i always buy 2 anyway
Also can you get eon E54xx instead of the older E53xx ? You should be able to get a E5410 for the same price as a E5320, its faster got more cache higher FSB 45nm, should be the same for all E53 vs E54 chips.
That sounds ok for a basic SQL server setup, but chances are we can do better if look at the I/O profile of your business application. Is it tempdb heavy (tempdb on it's own array)? What's the read/write operation ratio? Are particular tables hit more than others? (you could setup a second mssql file for those tables on it's own separate array) And how much data are we talking about?
Ben
We use Dell 2950s with 6 x 300GB 15k SCSI in RAID5 with one as a hot spare for database stuff. Works very well. 8 cores, 8GB RAM. :)
Seems a bit overkill you may as well do backups to another machine over gigabit lan or something. Backups on the same machine physical is a bad idea anyway.
As it's not my DB, I cant answer that, however it has 5/6yrs worth of data, the DB itself is about 5GB and the tempdb is only 8mb at the moment, but it's not being used being a sunday. The application itself is made up of multiple programs (mainly vb written) and obviously it runs one app per user as they go into different parts of the software. it did fall over last week when someone ran a report on stock levels.
At the end of the day, as like everything they buy, they always look to the cheapest option and expect it to last years, they do the same with desktops and laptops of which generally the laptops last 6-12 months tops and they just buy another £350 laptop
The backup arrays are usually used as a staging area for tapes, transaction log backups and being able to roll-back your database quickly in the even of data corruption. Plus you want to get you backup done as fast as possible so you need a local drive. Backing up directly to a network drive is out anyway as SQL Server won't talk to network drives.
If it's just 5Gb of data you'll be laughing with that server.
akakjs
While the DB itself isnt huge, I dont know how much of a mess it's in due to all the application development changes over the years, new stuff added randomly
The idea around the backup is Backup Exec on the TS box and the SQL Agent on the SQL box and backup across the lan and next year they are looking to get an email server, but I'm not looking forward to seeing what they dont want to spend there.
