TSQL - remove string from column
8 Mar 2005
London, UK
I'm trying to find the easiest way to strip out strings which match S-1-5-21-* (stale user SID) from a space deliminated column where there could be multiple matches.
Code:
Orange    paul john david
Apple    Paul S-1-5-21-100-123-43211 john
Banana    S-1-5-21-321-999-65123 lisa emma S-1-5-21-321-999-65111
Carrot    S-1-5-21-321-222-11111
Apple    Paul john
Banana    lisa emma
Carrot
Looking at PATINDEX,SUBSTRING,REPLACE or some elements of REGEX perhaps.
TIA, Paul.
Could string split I guess.
select value from STRING_SPLIT('S-1-5-21-321-999-65123 lisa emma S-1-5-21-321-999-65111', ' ');
gives
1 S-1-5-21-321-999-65123
2 lisa
3 emma
4 S-1-5-21-321-999-65111
Then looping through, discarding what you dont want, putting the rest back together and updating the column.
Dunno if you can do it all in one update statement.
so you want to replace all of the underlined bits? S-1-5-21-321-999-65123 lisa emma S-1-5-21-321-999-65111
Remove the entire string which matches S-1-5-21* from the column so that only resolvable user accounts remain.
I suspect a sub-query is needed; I'm just useless at trying fathom that with the match.
Code:
Apple    Paul john
Banana    lisa emma
Carrot
TIA, Paul.
Given your data above, which is a little hard to see exactly/a bit flakey is this the expected result?
Apologies; should have made it clearer (you cannot tabulate in the embedded code tags):
Code:
Col1      Col2
Col1      Col2
Apple     Paul john
Banana    lisa emma
Carrot
If I run the below stored procedure it produces this.
Code:
CREATE PROCEDURE [dbo].[FixColumns]
AS
BEGIN
    -- SET NOCOUNT ON added to prevent extra result sets from
    -- interfering with SELECT statements.
    SET NOCOUNT ON;
    DECLARE @ColId int, @OriginalCol nvarchar(500), @newcol nvarchar(500);
    DECLARE @ColValue nvarchar(500)
    DECLARE @NewColValue nvarchar(500)
    DECLARE @SearchString nvarchar(10)
DECLARE fix_cursor CURSOR FOR
SELECT ColId, OriginalCol
FROM testTable
ORDER BY ColId;
    SET @SearchString = 'S-1-5-21%';
     OPEN fix_cursor
    FETCH NEXT FROM fix_cursor INTO @ColId, @OriginalCol
    IF @@FETCH_STATUS <> 0
        PRINT '         <<None>>'
    WHILE @@FETCH_STATUS = 0
    BEGIN
        DECLARE col_cursor CURSOR FOR
        SELECT value
        FROM STRING_SPLIT(@OriginalCol, ' ');
                OPEN col_cursor
                    FETCH NEXT FROM col_cursor INTO @ColValue
                    SET @NewColValue = '';
                    BEGIN
                    IF @ColValue not like @SearchString AND @ColValue <> ' '
                        BEGIN
                        SET @NewColValue = @NewColValue + ' ' + @ColValue;
                        END
                    END
                        CLOSE col_cursor
                DEALLOCATE col_cursor
                --PRINT '(' + @NewColValue + ')'
                SET @NewColValue = TRIM(@NewColValue);--, 2, LEN(@NewColValue));
                UPDATE testTable SET Newcol = @NewColValue WHERE ColId = @ColId
        END
    CLOSE fix_cursor
    DEALLOCATE fix_cursor
END
GO
Yikes OK thanks.
Eh, look like SQL server 2012 doesn't recognise TRIM as an in-built function ): I do have access to 2017; let me have a thunk.
This should work if all the SIDs are the same length
NAME S-1-5-21-321-222-11111 MY_NAME
SELECT STUFF('NAME S-1-5-21-321-222-11111 MY_NAME', PATINDEX('%S-1-5-21-%', 'NAME S-1-5-21-321-222-11111 MY_NAME') , 23, '');
RETURNS : NAME MY_NAME
So
SELECT STUFF(COLUMN_NAME, PATINDEX('%S-1-5-21-%', COLUMN_NAME), 23, '')
Insert each row with a SID to a temp table, loop through updating and copy back
So I cheated (: with
CASE WHEN UserNames LIKE '%S-1-5-21-%' THEN STUFF(UserNames, PATINDEX('%S-1-5-21-%', UserNames), 48, '') ELSE UserNames END AS CleanedUsers
No doubt an inefficient and clumsy way to do this but I'm only processing less than 5000 records.
Thanks, Paul!
Your life is being made difficult by the root cause of "not great" data
I do not disagree. In this instance it's associated user logon data from Citrix. I've asked the vendor numerous times but apparently there isn't an easy way to expunge entries where a domain user has been deleted.
For this exercise I'm just trying to clean up the reporting without the need to touch the Controllers. However, it would make sense to write a powershell script to strip stale entries from associated users.
Edit:
AND
Only strips the first instance of the pattern ):
Is it feasible to use a python script as a middle man, using regex, then import? I know databases dont like imports as one mistake wrecks database (thinking rapid start @ microsoft nav @ sql)
yes, but run it a couple of times and jobs a goodun.
