Tsunami MJR2
8 Jan 2007
Manchester
I am considering downgrading my full tower setup into something like the Tsunami MJR2 in a attempt at saving some space and a combined pc and SD HTPC.
http://tsunami.tobid.tw/front/bin/ptdetail.phtml?Part=PEM0004&Category=117939
Anyone got any comments on the Tsunami MJR2? I can't find anything on OcUK.
It will be holding:
Q6600@stock
DS2R
3gb Geil pc6400
X-Fi gamer
WD6400AAKS
Sony DVD±RW
probably use something like the orb for cpu cooling.
I may consider upgrading to blu-ray spec aswell if I can do it cheap enough.
Thanks.
dear god are you not going to have some serious heat issues! That is one very thin case! I guess a Q6600 at stock you might get away with, but if I were you I wouldn't be looking so small for something like that - what GFX u planning on using? hoping onboard
I was putting a AMD Athlon 64 X2 4850e and Gigabyte GA-MA78GM-S2H with onboard graphics but decided on the Silverstone Grandia GD01S-MXR now
