TT 120 fitting
18 Oct 2002
Isle of man
hi
I have just ordered a tuniq tower 120 and was wondering do you have to take the mobo out to fit it to a Gigabyte DS3 board? or will it bolt straight on?
It is highly advisable that you use the supplied mounting bracket. If the board is like the other 775 boards then you have no bracket anyway, so will have no choice as the Tuniq will have nowt to secure on ;). It is worth it as I have a huge amount of mounting pressure on mine and no bending or warping of the board whatsoever. Mounting brackets on the back of the boards are always better imo.
