I've just pinched a couple of Tt fans from my old Tt Soprano case as they're quieter (at 12v) than the Lian Li standard fans that came with my PC-7.
However, I'm unable to drop the voltage/fan speed. I'm assuming the little 3 pin connector going to my mobo should allow me to adjust the voltage.
With these, there's a single yellow cable going to the mobo on the 3 pin connector and the power is coming from standard 4 pin cables (i.e. IDE HDD power).
The fans work without the yellow cable plugged into the mobo, so I'm thinking they must have another function - to adjust the voltage, but I can't get it to budge
