TT Armour and swiftech
4 Aug 2006
Stevenage , Wisbech
Just ordered a TT armour, ive got a swiftech apex ultra watercooling kit. I was going to install the rad on the back of the case, but looking at a review they mentioned they put the rad in the drive slots in the front. I think it takes up 6 of the 11 in total (leaves 5 for res, dvd writer and on off switch).
Has any one here done this ? If so was there any problems ?
hi m8 , a dual rad fits no problem in the armor. i have mine there with 4 scythe fans (2push/2pull) and it also cools the rest of the system that way.
heres my front of my armour :) (shame iv not got the fans hooked up to a rad yet, there just for air cooling at the moment
Nice one! Guessed it would as the LCS version has it in there but i wasn't to sure if the swiftech Rad was slightly wider. Ive only got a double rad as i want 3 or 4 external bays (one being the res). Which way is your rad mounted? Tubes at bottom or top?
I use the two blue fans which came with mine have one on the hdd cage and one standing by cable ties it looks like i got a 2fan rad on the from of my case looks pretty sweet. I put a akasa amber as the back fan and replace the other 2 fans with ambers aswell...
Cheers, going to fit my Radiator with the connectors at the top (it has been running "upside down" on my last case) with the reservoir in the very top bay.
inside my case its 26c right now (according to my motherboard)
my two hdd's are at 28c and one 29c
my cpu is 27c (intel TAT)
gpu is at 33c
gpu ambient is at 28c
looked at that post the other day looks good, but the case does need somewhere for cable management but ill sort out that when its all nice and happy. Think ill keep the fan grill on as last summer i ended up with a case full of shredded daddy long legs!! :D . Still keep finding bits of them when i clean my case out!!
btw them pictures are taken from my old layout. since then iv got a new motherboard gone to core2 duo. got another hdd, sorted my cables out. etc :)
