TT Mozarts Are In Early
Are these for servers or something? I expect a lot of empty space with most setups, although it might be nice for internal watercooling :confused:
Fatboy said:
Thermaltake TT1225 - L12S is all it says if that is any use.
Cheers. :)
- Dimensions: 120 x 120 x 25mm
- Rated speed: 1400 RPM
- Sound: 21.0 dB
- Air flow: 41.6 CFM
- Bearing: 1 Ball, 1 Sleeve
- Life expectancy: 50,000/ hrs
- Volts: 12
- Amps: 0.30
Ok specs really, think this is the model that is just slightly worse than ambers in DB : CFM.
I was wondering home to justify the home extension - Now I know just got tell the bank manager I need more room for my PC and slap a pic of that monster down!
Looking forward to some pictures of the crazy systems people build in these we should see some hardcore watercooling
A couple of thoughts,
1: Does anyone make a 240mm fan? One of those in place of the 4 120's would be superb! :p
2: It says dual motherboard, I assume that means 2 seperate motherboards but there only seems to be space for one set of IO's? :confused:
3: Why would you need dual motherboards anyway?
:D
