TT Shark help
14 Apr 2007
I just recently got the TT Shark from OC and i must say the case is a great step up form my 3year old lavalamp style case..
Lots of space, docking bays and cradles...
I am sing it with a Tagen 700w and putting my old setup in the case untill i get my new one, the only problem i have at the moment is the i/o panel on the back.
My current motherboard has onboard lan and the bottom part of the i/o is different to the one that came with the case, i have tried to remove the i/o panel to put the one i currently use in but to no success, i have tried ot do it without damaging the case but for the life of my i cant get the i/o panel off.
Any advice would be great.
Is it not just a piece of metal that either breaks off, or has 2 screws to hold it in place?
Its been a while since ive seen the TT shark so I may be wrong.
