Tt TMG i7
8 Nov 2002
Parson Drove near Wisbech
I have this cooler on my E6600 at the moment and I was wondering if you brilliant overclockers out there could give me some advice on getting a better cpu cooler I have a 120 mm pulling in at the front a 120mm on the side pulling out over the cpu and another 120mm at the back pulling out,the Tt TMG i7 is not too bad 38oC on idle but I know you can get that down and with prime it sits between 59oC and 70oc Also when the fan on the cooler runs low at idle it drops below 300rpm and i get the warning bells because my motherboard will only go as low as 300 so I have to set it at 50% on low to stop the alarm.
Any help you can give or advice you have will be great, Thank you for looking.
Regards, Wayne..
