So my brand new TT case arrived today, and before I start installing stuff, I was trying to figure out how to set up the fans so that I'll get the case cooled nicely.
Here's the case: http://www.thermaltake.com/product/Chassis/midtower/m9/vI1000bws.asp
The case provides 2x 120mm fans, which are positioned in the front and the rear of the case.
I was wondering if I'll screw up the airflow by installing 2x 120mm on the side window panel, blowing air on the CPU and VGA (Q9550 with Arctic Cooling Freezer 7 Pro, 4870 Stock Cooler).
Also it's possible to fit a 120mm fan in the front above the other one, would that make any difference?
I was thinking something like:
OR
Any ideas and suggestions are very welcome.
), like the Antec 300 does, so I'll try the first setup and see how it goes heh.
