Right need some help guys..
I have got the "Speed Zoned Complete 34 Files" from Pocketworldgps.com and wanted some better alerts..
Now in a previous general thread I got told..
Tried following the last link and downloaded the Ogg files. I sort of renamed them but have tried putting on the SD Card and however the TT doesnt pick them up so im doing something wrong..
Help please!?!?
Also if it helps:
App 6.501
OS:1343
GPS v1.21
Boot 4.81
UK~RoI v660.1199
Simian said:iirc all version 6 software since v6.15 you can, if not just update the firmware to 6.52 (the newest!!), then all you need to do is...
1) make some .ogg sound files for each POI,
2) name them identical to the POI just like the .bmp for it, eg: TVR_UK.ov2 with TVR_UK.bmp you make TVR_UK.ogg.
3) Put the .ogg file in the same directory as the POI (The UK Map Directory).
4) Activate the 'Warn When Near POI' and it'll automatically select the sound file you've made!.
You can always get some ready made voices!...
http://www.tomtomsatnav.info/voiceskins.html Here for Voice 'Direction' Skins (Vicki is my favorite!!... Nicer than the Standard Jane).
http://www.tomtomsatnav.info/realvoice.html And Here for the .ogg files (which you need to re-name as the POI's!) at the bottom of the page!!!..
Help please!?!?
Also if it helps:
App 6.501
OS:1343
GPS v1.21
Boot 4.81
UK~RoI v660.1199
