I searched but found nothing, I'm sure someone will be able to point me to a dozen threads answering this questions but I figured it best to and ask directly.
So basically, I currently have an XSPC Bay Res/Pump combo, and I'm wanted to upgrade to a Tube res. and reuse the pump from the original Bay Res.
Problem is, I can only find an XSPC 170mm Res that has the compatable base to connect to the pump. Link below
https://www.overclockers.co.uk/xspc-d5-photon-170-tube-reservoir-v2-wc-42g-xs.html
I think 170mm is too big, so I was looking at an EK 140 or 150, like the one below
https://www.overclockers.co.uk/ek-water-blocks-ek-res-x3-150-reservoir-wc-313-ek.html
However, I want to mount the pump directly to the res and mount it to my case. but I can't seem to purchase the correct pump base anywhere.
Thanks in advance
Thanks in advance
