Tube reserviors
21 Oct 2014
I've got two EK x3 250 reserviors I'm mounting them side by side an the one on the left has an intake at the top, the coolant goes out the bottom inlet an into the bottom of the second red, then back out the bottom of the secon red, my question is do I mount them equal or so I need the one red higher than the other? Due to needing a space for air to escape??
You can mount them at different heights, but never ever have both open at the same time, even if you have them level with each other. Air will go in one, and water out the other!
As far as the loop is concerned a reservoir is just a bigger piece of tubing, so yeah doesn't cause an issue having them the same height.
