Tube reservoirs with multi option tops?
27 Nov 2008
Dublin,Ireland
Are there any decent ones out there apart from EK as i dont want to use there one again after issues with my 250 advanced?
I have searched but all i can seem to find are ones with just a fill port on top.
The way i have my loop i need at least two options on the top section of res.
Only other ones i can think of are made by koolance,you can't get them complete as far as i know you have to purchase a tube,bottom, top & brackets.
The only way around it with the koolance is to get an extra bottom as this will give you 2 x option which you can use as a top.
Google Bitspower Z Multi.
Thanks guys,i didn't think i could use two bottoms on the koolance and use the BP res the either way around. :D
