Hi all,
I had my custom water loop in my system for little while (6 months or so). CPU+GPU loop, dual radiator (240mm), pump and fairly big reservoir. Phobya compression fittings 13/10 ,a clear tube and silver kill coil.
Now:
for like 3 weeks I was running simple distilled water in my loop. Was ok. Later on I refilled my waterloop with Mayhems white pastel liquid. Not bad to be honest. But after 4 months, the tube went quite dirty/cloudy. Some of the parts are like new (clear but still cloudy), in other places tube is yellow in fact! The tube was some cheapest one bought from Scan..
Can you suggest me a good clear tube? That is not cloudy out of the box?
And I might get back to just distilled water.
Cheers
Nichrome
Now:
Cheers
Nichrome
