I'm new to the water cooling game, few quickies.
You can get OD tubing and ID tubing, whats the differance?
Also if my water cooling system uses 12 x 8 mm tubing.. whats all that about? 12 tubes with an 8mm width ?
This tubing for example: Zalman Blue Silicone Tubing 8mm ID/10mm OD (1m)
I get that it's 1m in length, but I have no idea what 8mm ID/10mm OD means.
Would be much appriciated if you could explain this to the nub
And could I use " DangerDen Tubing (Blue) 1/2" ID (1ft) " Instead of the Zalman tubing?
