Tubes advice
12 Jan 2011
Hi, it's been a while I was here. I looked around for advice what tubes use. It will be my 1st build so need some advise. I am changing that GTS to 2x GTS so cooling power will increase. I want to make a stealthy build with orange Mayhems fluid. Pump will be hiden in the basment under custom PSU shroud in the TT Core V21. I will do some bends but also I think about using some fittings/T fittings to use LEDs to light up the fluid a bit. Shall I use Black or Copper/Gold fittings?
I already have fans and Aquacomputer controller.
