Tubing & connector help pls
13 Aug 2012
Boston,UK
NZXT Switch 810 - Black (Apperantly best WC case right now)
I5 3570K OC to 4.8Ghz 24/7
Asus Z77 Maximus V Formula - EK Supremacy CPU block (Copper Acetal)
GTX 670 - EK FC670 GTX Acetal CSQ with Backplate
Another GTX 670 in the future or 2 x GTX 680, Not Sure
2 Rads - XSPC AX240 + XSPC AX360 (Push/Pull - Typhoons 120mm 1850rpm)
XSPC D5 Dual Bay Reservoir + Pump Combo
Mayhems Ultra Pure H20 Fluid
What tubbing do I need and what connectors or barbs for a tight fitting?
Cheers
Tubing fitting shouldn't matter as long as the ID/OD matches up. For a first time user I would recommend compressions (easier to fit, less chance of a leak etc...)
For example if you choose 7/16-5/8 tubing you're going to need 7/16-5/8 compressions.
Cheers:)
I definatly agree with the use of compression fittings if you like them go for it:) very hard to screw up a tight seal in my opinion. Great for water noobs like me haha
Barbs combined with hose clamps are just as effective as compression fittings IMO. Just go for what you think looks best.
