- 4 Jun 2010
Ok so I basicly think I have my loop sorted. As you can see my my amazing drawing I will be using a 700D with a CPU and GPU block. The plan is this:
RAD>PUMP>RES>GPU>CPU>RAD>
The picture is this:
**KEY**
Yellow - out
Black - in
The two extra holes on the rad - just ignore them, I was thinking of mounting my rad the other way.
The only rule I can seem to find is this
Thanks
Freddie![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
IDEA 2:
![looppath.jpg](http://img534.imageshack.us/img534/6312/looppath.jpg)
**KEY**
Yellow - out
Black - in
But would this setup still work and be safe?Only the res before the pump is important really and a res higher than the pump.
Thanks
Freddie
IDEA 2:
![watercoolinglooppath.jpg](http://img153.imageshack.us/img153/1021/watercoolinglooppath.jpg)
