14 Jan 2010 at 11:05 #1 Jason1973 Jason1973 Associate Joined 7 Aug 2009 Posts 485 Location midlands Hi all, I have tubing 12mm OD ans 8mm ID Can someone please tell what replacement tubing I need as it all seems to be in inches and fractions were never my strong point.
14 Jan 2010 at 11:37 #2 JonJ678 JonJ678 Soldato Joined 22 Dec 2008 Posts 10,369 Location England I haven't seen 12/8mm, though 10/8 and 11/8 are both common. Where did you get the tubing from, and are you using barbs or compression fittings? One of the imperial sizes may be close enough but I wouldn't like to guess.
14 Jan 2010 at 11:47 #3 shadowscotland shadowscotland Soldato Joined 31 May 2006 Posts 7,564 Location West London Zalman tubing is 12/8 I've use 3/8 (9.5mm ID) tubing with my Zalman Res2 - you need good clips over the barbs but it does work.
14 Jan 2010 at 11:50 #4 Jason1973 Jason1973 Associate OP Joined 7 Aug 2009 Posts 485 Location midlands @ jon thanks for your reply, @ shadow yes mate it is zalman tubing, on my res XT. Thanks for the size info can you recommend some clips?
