I really miss Tuna steak - had a recipe for Seared Encrusted Tuna Steak with Fresh Coriander and Basil. But can't find tuna here.
Except that just recently I came across a frozen seafood import shop that had some chunks of tuna. But the dimensions are strange. It's long and thin, and looks like it's meant for making sashimi. Basically:
4.5cm thick, between 9 and 11cm wide (slightly tapers), and 26 cm long. It's about £10.50 per kg and this block is about 1kg.
So, do you think it's possible to make anything steak-like with this? My current thinking would be to cut it in half, so I have two chunks 4.5cm thick, 10cm wide and 13cm long, then, if I can, slice in half so it becomes only 2.25cm thick, x10cm x 13cm, so sort of squarish, and about 273g each.
Or do you think it's not worth the hassle?
