16 Oct 2008 at 22:14 #1 dokko dokko Soldato Joined 26 Nov 2005 Posts 3,839 Location Doon the Bay (Newcastle) unloved, abused PC which is crawling. Can't do a reinstall just yet, but want to sort out a quickish fix for a friend, what tools could i use? got to be free btw. (Done tun up utilities) ta.
16 Oct 2008 at 22:29 #2 Pigeon_Killer Pigeon_Killer Caporegime Joined 21 Nov 2005 Posts 41,855 Location Cornwall Antivirus - Avast/AVG/Avira Spyware - Ad-Aware/Malwarebytes/Spybot S&D System Optimiser/Registry Cleaner - CCleaner I'd also run Disk Cleanup and Defrag.
16 Oct 2008 at 22:43 #3 Dano Dano Soldato Joined 19 Dec 2006 Posts 10,521 Location UK chkdsk with all the options too.
17 Oct 2008 at 09:40 #4 Brian Stuart Brian Stuart Associate Joined 23 Oct 2002 Posts 2,203 Location N Ireland Try Super Antispyware as well There is a free edition and I have found it is very good.
17 Oct 2008 at 09:50 #5 bledd bledd Don Joined 21 Oct 2002 Posts 46,882 Location Parts Unknown disable system restore ccleaner nod32 av trial (for a one time scan) spybot s&d o&o defrag trial (will work wonders) also, startup lite http://www.malwarebytes.org/startuplite.php ^prevents crap like quicktime, google plugins and unneeded driver tools from loading up
17 Oct 2008 at 11:28 #6 dokko dokko Soldato OP Joined 26 Nov 2005 Posts 3,839 Location Doon the Bay (Newcastle) Thanks guys this is all excellent stuff. Having a problem with a rundll32 file not working on startup, any ideas?
17 Oct 2008 at 21:00 #7 modo77 modo77 Soldato Joined 31 Aug 2004 Posts 3,656 Location Sol System Start>Run>sfc /scannow It may ask for the windows cd if it needs to replace anything.
