Tuning Ryzen voltages down
19 Oct 2004
London
I need some help tuning the voltages down on my 3950x
I've got an a ccd overclock going with cores ranging from 4250-4350 at just under 1.3v
My memory is 2x16gb is running at 3733, with tight timings (14,15,8,13,29) at 1.5 volts (g-skill b die)
it's under a custom loop so never goes over 60 degrees while gaming or working (prem pro/after effects etc)
but i want to take all the other voltages down. Can someone help
They are
CPU NB/SOC 1.15
vddg iod 1.1
vddg ccd voltage 1.15
vddp 1.1
Everything else on auto.
Also i keep getting a random re-boot in warzone which is really annoying (it's almost always when i reach the top 10) - it's not crashed in anything else
My memory has a temp monitor in it and the highest I've seen is 43 degrees - though that checking as the reboot so it may have cooled down by the time I get to look at it.
I'm on an msi unify x570, bios is 92 i think.
Thanks
