tuniq fan
21 Jan 2008
England
looking for a replacement fan for the tuniq tower. (120mm)
needs to move the most air possible, but not be too noisy.
some kind of LED'd fan would be nice, but doesnt matter at all if it means getting better performance with another one.
also yno how the tuniq has a little fan controler? would it be possible to hook the new fan too it? orr...:o
thanks
Mine has a yate loon H in it. No LED, but moves a fair bit more air than the default, and is quiter.
You CAN wire the new fan through the controller but it will mean soldering or using terminal blocks.
I put mine through my front panel akasa controller (I took the "roof rotor" of the antec900 off the controller and put it back on direct power to make room)
