Tuniq Tower 120 CPU Cooler
8 Feb 2006
Stafford
1stly
can you change the fan
and does it take a 120mm one
thanks
also does anyone recommend it for a q6600
yeah its bloody worth it! arguably the best cooler there is! just make sure it fits your case, its massive!
furrymuff, but I think you should see what the existing one is like before you go buying a new one, I'm not too sure if you need to upgrade it
reviews are dictating that its an excellent cooler but the fan is noisy when on full,also i'll have 2 x 120mm scythe kaze whites spare when i rid myself of this ifx14
no reflection on thermalrights gtx cooler however, thats the nuts
