Tuniq Tower 120 CPU Cooler
yes it can:)
I'm sure that if you removed the controller the fan would just run at full speed.
yes it would, unless you get the motherboard to control the supplied voltage to the fan, which is what the op was asking lol
Is it easy to remove the controller? I'm finding that the cables connected to it are a pain in the ****
Yah looks like the one - not terribly professional but handy if you want some pointers on how to fit it.
Edit - seen another somewhere with more detailed fitting instructions.
