Tuniq tower 120 - what way to position?
6 Mar 2007
Hi
I have an Akasa 62 with my exhaust fan at the back and wonder which way my Tuniq 120 should be facing.
My setup is not disimilar to this picture
Can someone with a Tuniq have a look at the picture and describe which was it should be facing.
Thanks
Have the tuniq that way around so the fan is sucking air from inside the case and out towarsds the rear exhaust fan which should also be blowing the hot air out of your case :)
I have atuniq, and its mounted exactly the same way. The exhaust points to the rear of the case, and straight into the rear case fan. The quicker you get the hot air out the better.
i thought the correct manner was to have the fan blowing
toward the rear not sucking.I had one delivered today i will try both configs
and keep whatevers best but at a guess both will be about the same.
I mate
in the picture you have posted the TT 120 is in the right position
also the cables and wires were very nice tied -up
nice work :)
I have mine blowing up so the warm air is sucked out the psu and my top blow hole. My rear case fan is blowing in as is the front one. Currently running tat/orthos and max cpu temp ([email protected]) after 16minutes is 40 degrees. CPU fan at 857rpm.
