I have a tuniq tower coming on Monday, from the concensous of the web it seems sticking the backplate down is not such agood idea, should i just not stick it down and leave the protective cover over the sticky pad on?, will it still all be ok?
Van Diemen said:Yeh, dont stick the back plate down. Its a nightmare to remove. If you have problems fitting the cooler, you can masking tape or blue tack the back plate until the cooler is fittet, then just remove the masking tape.
Vtec9k said:Just fitted mine today and thats exactly what i did too.
yes exactly that, use masking tape or blue tak to hold the back plate in place - and once the TT is screwed into it that will hold it in place and remove the blu tak and masking tapeTom|Nbk said:what you didnt stick the backplate, or you used blu-tak etc?
