- 1 May 2003
It would seem that the fan inside my tuniq tower 120 is dying on me. I am gussing that even if it does go kaput, its not gonna drastically change the heat around my cpu too much?
you would be surprised. but i may be wrong.
I know its a different cooler, but i removed the fans off my D14 and my pc shut down when it got too hot, it went from mid 50's.C while gaming, to over 80.C
just stick another 120mm fan in there
a guide for whats it worth, about replacing the fan
http://www.overclock.net/t/211069/guide-replacing-the-fan-in-a-tuniq-tower-56k-warning
I have one on my kids pc, its only 4 screws to slide the fan out
disconnect the fan from the header, and see if the temps are high, if not, then you know you dont need to replace it.
