Tuniq Tower help quick question!!
Permabanned
29 Jun 2007
Benfleet essex
or two...
1. The fan connector on the TT to plug into the cpu_fan on the motherboard is 3 pin, but the motherboard cpu_fan is 4 pin. I can still plug it in fine, is that ok to do that?
2. I want to control it using this zalman fan controller
instead of the back of the case PCI plate fan controller that it comes with. but the connector on the TT to control it is only 2 pin..I dont think this zalman supports that. Is there any way to do it? Could I replace it with an akasa amber fan which is standard 3 pin? I dont think it can be replaced though cause theres nothing to hold it in place..
actually your right i think i can :) but is one of these amber fans powerful enough for it (1400rpm)? I wouldnt run at 2000 anyway if its noisy at that speed.
You can run a Tuniq fine off that controller with the default fan. I know this as I have this controller and a Tuniq ;)
Tis' an awesome controller aswell :cool:
