Tuniq Tower in an Antec Nine Hundred??
should be no problems, looking through some spec checks these 2 have been recommended so it seems so, let someone confirm though
Sh4rkie said:
Fits fine but you will loose the ability to have the optional side grill 120mm fan installed.
Was about to say the same thing as well, also the reason why im getting a highend better and bigger case.... ive learned from my mistakes completly now... im gonna go for the biggest case peroid.
That way everything fits in and its an breeze to work on and no chance for heat to build up even ;)
Antec Nine Hundred
The power switch lead was too short to reach the slots on the Asus P5N-E SLi nForce 650 (Socket 775) PCI-Express DDR2 Motherboard it was like 3" - 5" inch too short but part from that the tuniq tower fits reallt tight n too close for my likeing too some circuits sould be ok i hope any idears??
i have the scythe ninja cooler and i think it was of similar size and had to cut a corner of one of the fans off to get it too fit. not sure if its worth looking at that
