Tuniq tower problem help
24 Aug 2005
Uranus
Just installed my tuniq tower 120, all was ok for a few hours then the comp froze after that no post no beeps nothing. Removed tower tried to remove back plate but the adheasive foam has stuck it on good anyway backplate came off foam stayed on the motherboard :confused: artic cooler back on now it posts ok wtf has any one else had this problem is it shorting out the board or sumat how can i solve the problem?
If i put some cardboard between plate and motherboard would this help stop short circuit?
