Tuniq Tower question
6 Nov 2005
Newcastle,UK
I have just built a system with a Core2 E6300 on a DS3 mobo with the Tuniq, however when I tighten down the Tower the system will not boot :confused:
The only way to solve this is to loosen the Tower which then lets the system boot as normal, however with the Tower lossened off a bit it does have a little bit of movement on top of the CPU, so my question is this - how loose is safe with regards to the Tower?
Temps seem fine both idle and under load, so it would seem that there is still good contact between the cooler and the CPU, I am just a bit concerned with how loose the cooler is.
Cheers for any help.
Bry.
