Tuniq Tower Question
Permabanned
20 Feb 2006
Edinburgh
Will the Tuniq Tower fit on my Asus P5B-E and will i have any problems putting the tuniq tower into a thermaltake soprano case ?
It will fit your mobo fine, the case i would measure from the mobo edge to the case door and leave some space on top of that so the fit isnt too tight. Heatsink Dimension: 131mm (W) x 108mm (H) x 153mm (D)
