I've got a bit of an unusual problem with the Tuniq tower CPU cooler.
Basically my system works nicely, good temps and all the rest of it. Then randomly a week later the system will freeze up, and after rebooting, will not post.
Remove the tuniq, put it back on (or stock cooler) and the system posts and is fine.
I have done this 3-4 times now and its extremely frustrating after just spending a considerable amount upgrading my PC. The tuniq fits perfectly and is not shortening a capacitor out or anything silly.
I am not sure I can justify splashing out on a new board when I know this one works perfectly when a stock cooler is used 24x7. I am wondering whether it's just the shear stress the tuniq puts on the board through the bracket which is causing the issue.
If anyone has any clus it would be great.
Thanks.
Thanks.
You could try with the case on it's side to see if this might be the problem.
