I have been tinkering quite a bit today to see i f i can get to 3.6Ghz on my
Q6600 with little success.
I have a few thing against me like a VID of 1.3250 and a third core that keeps giving me a rounding off error after 30mins of prime95.
Now i got up to 3.25Ghz using a Vcore of 1.41 but the temps got quite high ie. 69,69,65,65.(measured using coretemp)
My idle temps are usually between 32-35c.
I use at the moment an AC7 pro for my cooling needs, my case is Antec P182 with all the fans on low.
My motherboard if relevant is the Asus P5K Premium.
My question is this, is a Tuniq tower going to improve my temps over the AC7 or do i save for a while and go water?
Any input would be appreciated.
I really believe 3.6 could be had with adequate cooling and sufficent voltage, i know all kit is different but i have faith. I will say i have post at 3.4 before now and got into windows, but other than reading emails i couldn't really use it. It failed prime95 after approx 0.235 seconds.
Cal.
Cal.
) and thinking of upgrading to a TT.
