Lo all
I have been following varous CPU HSF threads on here and eventually bought a AC7 Pro due to cost concerns - Mistake!!. After 3 reseats and using AS5 it does no better than the stock cooler but is louder under load
But dont really want to discuss the AC7 as its been talke to death else where
going to invest in a Tuniq tower
as i cannot find anything bad said about them.
I have the room in the case but wanted to check it would fit with my Mobo, Asus P5WDG2 Pro. Only checking as a few people have had issues with caps getting in the way of the mounting bracket
Has any one fitted this cooler to this Mobo ?
cheers
.But dont really want to discuss the AC7 as its been talke to death else where
.going to invest in a Tuniq tower
as i cannot find anything bad said about them.I have the room in the case but wanted to check it would fit with my Mobo, Asus P5WDG2 Pro. Only checking as a few people have had issues with caps getting in the way of the mounting bracket
cheers
. I'm going to slack the timings off my RAM and push it up to 3Ghz and see how the Tuniq comes then, if it goes over 56 I'll back off I think
