- 4 Apr 2012
In my mobo you can either raise the CPU ratio (all cores at once), or you can raise the turbo boost ratios for each core individually. Enabling turbo boost also allows you to set turbo power limits.
If I want 44x ratio on all my cores, is there any benefit in enabling turbo mode and setting each core individually to 44x, instead of disabling it and just setting 44x for all cores at once with the CPU ratio? In other words I'm asking if there's any point in using the turbo boost function. I've got C1E, C-states, and Speedstep enabled so I don't think turbo improves power saving in any way. Maybe it improves stability (thanks to the turbo power limit settings)?
