[FONT=helvetica,arial]Why do manufacturers fit a dump valve?[/FONT]
[FONT=helvetica,arial]It is for a number of reasons. Without a dump valve, when the throttle was closed, the build up of boost pressure would be immense, very similar to closing a quickly flowing water tap. This excess of pressure, (which could be over five times the running boost pressure), would put the components of the system under a great strain. It would try to burst the intercooler and pipework. More significantly, it would put a large strain on the turbocharger itself, firstly stalling the compressor shaft, then trying to force the compressor wheel out of the turbo, against its bearings.[/FONT]
[FONT=helvetica,arial]So, the dump valve prevents mechanical damage to the intercooler & turbo pipework, prolongs turbocharger life, and prevents excessive turbo - lag that would be caused by the compressor shaft stalling.[/FONT]
