- 19 Jan 2006
Hey guys,
Just noticed a slow down on my computer where it froze for half a second then worked, froze for half a second then worked and it happened over and over.
I checked the temp on my X1900XT with an Accelero S1 and at it was around 75 degrees. I believe this caused the slow down as when it dropped back down to around 60 everything was fine again.
I never had this problem before but I've just recently switched to a 22" widescreen so the extra resolution is obviously straining the graphics card more and causing higher temps.
So my question is should I get the Turbo Module and attach that or just whack a spare 120mm fan in the gap?
Thanks
Jonny
Thanks
Jonny
