I have just sold the contents of this case on MM. I have a Fractal Define Case which i want to free up to get it repainted (another thread when this happens) so i wanted case to move the bits into without having to buy one. If you look at the inside of the kolink it has a vast amount of unused space with vertical slots that have no apperent use (maybe for water cooling reseviors). I thought could i mount Hard drives similar to the Phanteks P400. My 3D skills are limited to AutoCAD so its not great but should do the job. Ive set the below printing now to see how it turns out. and got some nuts and bolts coming in post.
dont have any white at the moment so im having to use Grey. I will update later if the print is successful and lines up in the case
