- 12 Feb 2006
- Surrey
will be buying a 24" monitor soon and wish to use it also as a tv but as i will be buying a computer monitor over a television i will be getting none of the features the tv provide like remote control for on/off, channel changing ie bbc1/2/itv/4 etc, scart connections for the dvd playey/wii/brothers xbox, and antenna for virgin box.
can you guys help me out as to how possible this is, ie what hardware i will need and if using a monitor as a tv actually looks good, unsure as differnet resolution though would have thought it would look better and not worse.
most likely will be giong for this monitor in next couple of days
http://www.overclockers.co.uk/showproduct.php?prodid=MO-055-HY&groupid=703&catid=17&subcat=510
though possibly i might change to the below if i can find one that is non hc
http://www.overclockers.co.uk/showproduct.php?prodid=MO-019-DE
i have posted a thread in monitors section but as it's mostly for which monitors and im not getting many responses about turning it into a tv aswell i firugred best to post it here.
forgot to say that the reason for doing this is that i am wanting to new tv and another monitor to go with my current 20.1" but i only have the room for one and as pc is more important to me and afaik using a monitor as tv is better then tv as monitor is much better i am opting for this way. The tv will be used mostly just at nights when pc is off and i am drifting off just hit off button and im asleep so i don't want to use anything that needs to be plugged into the pc if possible.
