Devolo 1144 dLAN duo adapter – HomePlug 1.0/ Powerline @ £38.00 inc VAT
MicroLink dLAN duo is a HomePlug adapter - Internet access extension and home networking using your existing household power circuit.
PRODUCT FEATURES:
The easiest broadband extension into any room and onto any floor in the house, simply by connecting a MicroLink dLAN duo adapter to an Internet enabled ADSL/ cable modem's Ethernet interface; and plugging it into a power socket!
No new cables, no drilling, no mess! Just use any power socket to access the Internet or home network throughout the whole house;
Ethernet or USB PC connection? The choice is yours... The MicroLink dLAN duo adapter has both, so you can choose either!
devolo Power-Saving mode - 30% less power consumption when not in use;
Perfect for connecting games consoles to the Internet (e.g. X-Box, PS/2 via Ethernet);
Installation? Child's play! Simply plug the MicroLink dLAN duo into the power socket and connect it to the PC's interface; install the supplied software - and go!
Data rates of up to 14 Mbps over your existing household power supply;
Ranges of up to 200 meters - thick concrete walls and multi-floors are not a problem;
Very compact design: no bigger than a mains power adapter!
Highlights of the Devolo dLAN duo adapter – HomePlug 1.0/ Powerline
- The easiest broadband extension into any room and onto any floor in the house, simply by connecting a MicroLink dLAN duo adapter to an Internet enabled ADSL/ cable modem's Ethernet interface; and plugging it into a power socket!
- No new cables, no drilling, no mess! Just use any power socket to access the Internet or home network throughout the whole house;
- Ethernet or USB PC connection? The choice is yours... The MicroLink dLAN duo adapter has both, so you can choose either!
- devolo Power-Saving mode - 30% less power consumption when not in use;
- Perfect for connecting games consoles to the Internet (e.g. X-Box, PS/2 via Ethernet);
- Installation? Child's play! Simply plug the MicroLink dLAN duo into the power socket and connect it to the PC's interface; install the supplied software - and go!
- Data rates of up to 14 Mbps over your existing household power supply;
- Ranges of up to 200 meters - thick concrete walls and multi-floors are not a problem;
- Very compact design: no bigger than a mains power adapter!
Only £38.00 inc VAT.
ORDER NOW
Devolo 1382 dLAN Highspeed Ethernet II Adapter - HomePlug 1.0/ Powerline @ £48.00 inc VAT
The high-speed HomePlug adapters connect your computers and bring the Internet into every room of the house over the electrical wiring. Now with patented power save mode and new, clearly arranged 3-LED design.
With the devolo dLAN Highspeed Ethernet II, setting up your home network is a breeze - and you will not even have to bother with installing cables. Unlike wireless networks (WLAN), thick walls and long distances make no difference to HomePlug. The HomePlug technology uses the household electrical wiring as if it were a long network cable - offering a range of up to 200 m (656"). Fast and secure surfing on the Internet with high transfer rates of up to 85 Mbps and DESpro encryption. No complex configuration is required for installation: plug the adapter into the power outlet, connect it to your computer via the network cable and you are ready to go! Now you can expand your home network at any power outlet in the house using additional adapters. The user-friendly software allows individual password assignment for even more security.
Highlights of the Devolo dLAN Highspeed Ethernet II Adapter - HomePlug 1.0/ Powerline
- Network your computers (Mac/PC) and other network devices quickly and easily over the electrical wiring
- High transfer rates of up to 85 Mbps
- No configuration is necessary - plug it in and enjoy
Only £48.00 inc VAT.
ORDER NOW
Devolo 1218 dLAN 200 AVeasy adapter - HomePlug AV/ Powerline @ £54.90 inc VAT
dLAN® 200 AVeasy – your fast home network
dLAN® 200 AVeasy connects network-enabled devices such as PCs, modems, routers, game consoles and set-top boxes via your household power grid. It complies with the new HomePlug AV standard and supports data speeds of up to 200 Mbps. Its speed opens the door to bandwidth-intensive applications such as Internet television (IP-TV in HD quality), video-on-demand, VoIP telephony and fast Internet access – with "Quality of Service" for smooth operation. It achieves a range of 300 meters within a single household grid, giving you the greatest possible flexibility to use your applications throughout the house.
Network access from any electrical outlet
Just plug the dLAN® 200 AVeasy adapter into an electrical outlet to turn your power grid into a convenient data network. All you need is two adapters to take advantage of the full range of services. If ever you decide to use a room for a different purpose or rearrange your office – no problem. Your network moves with you – without the need for laying new cables. Just plug the adapters into different electrical outlets. That's it!
Maximum data security
The special feature of the dLAN® 200 AVeasy adapter: a touch of a button is all it takes to activate powerful 128-bit AES (Advanced Encryption Standard) encryption for maximum security. No additional software is required. Locking down your network couldn't be easier!
Secured networking at a touch button.
- Simple plug-and-play networking of a range of devices via the household power grid
- Speeds of up to 200 Mbps, data encryption at the touch of a button
- "Quality of Service" for smooth operation of modern multimedia applications
Only £54.90 inc VAT.
ORDER NOW
Devolo 1145 dLAN duo Starter Kit – HomePlug 1.0/ Powerline @ £65.00 inc VAT
HomePlug adapter with Ethernet and USB interfaces for flexible data communications over the household power supply.
HomePlug adapter with Ethernet and USB interface for data transfer via the existing household power supply.
- Ethernet or USB — the choice is yours
- Power-saving mode, less than 30% consumption of electricity
HomePlug – a new dimension in networking
Networks have become an indispensable part of our daily lives, and flexibility is more important than ever. But not everyone has the necessary expertise to deal with network technology, and technical independence always comes at a cost.
devolo has the solution to this dilemma!
Thanks to HomePlug technology, you can now set up a home network easily and economically. You will not believe how simple it really is! Just connect your PC to a dLAN® adapter and plug it into a power outlet to transform your household power grid into a fully functional network. With dLAN® technology, you can surf the Internet and access other PCs or printers from any power outlet in the house. Simply take the adapter with you whenever you switch to a different PC or another room.
The actual connection to the Internet is realized over your telephone line as usual, leaving you absolutely free with regard to the type of connection (ADSL, ISDN or analog) and your choice of provider and rate.
Only £65.00 inc VAT.
ORDER NOW
Devolo 1360 dLAN 200 AVplus adapter @ £59.90 inc VAT
The dLAN® adapter that has more to offer: integrated power socket and mains filter for more convenience and higher performance.
- dLAN® 200 AVplus quickly and easily establishes a network connection over the household electrical wiring
- The integrated socket ensures that no electrical outlet is lost.
- The integrated mains filter improves data transmission in the home network
- Transfer rates of up to 200 Mbps - for applications that require a high bandwidth
- Easy data encryption at the touch of a button
- Perfect network performance
The new HomePlug AV adapter from devolo provides extra convenience for your private home network with its integrated electrical socket and mains filter. The integrated electrical socket enables additional terminal devices or multiple sockets to be connected to the adapter just like to a normal wall socket. No power supply is lost. And the integrated filter significantly improves data transmission in the home network.
The dLAN® 200 AVplus transmits bandwidthintensive data easily and securely over the existing electrical wiring – without installation effort. In addition, the "Quality of Service" function prioritises the bandwidth requirement of the data traffic, which has a speed of 200 Mbps, thus ensuring maximum voice and video reproduction. TV and video images are received and displayed with absolute smoothness. QoS also guarantees the clear, instant reproduction of voice data, even when other applications are running on the network at the same time. QoS makes your network a joy to use!
Only £59.90 inc VAT.
ORDER NOW
Devolo 1540 dLAN 200 AVSmart+ Adapter with LCD Screen @ £65.91 inc VAT
- Quick: The devolo dLAN® 200 AVsmart+ offers a transfer rate of up to 200 Mbps to a cable length of 300 metres.
- Easy: True plug & play - the encryption button makes it possible to start up easily and securely. Without a computer, including encryption.
- Clearly arranged: The dLAN® screen display developed in-house by devolo shows the connection status with other powerline adapters.
- Convenient: The integrated socket ensures that no electrical outlet goes to waste. Furthermore, a special mains filter ensures best possible transmission.
- Efficient: Thanks to the intelligent Dynamic PowerSave technology, the dLAN® 200 AVsmart+ reduces its energy consumption automatically by over 60 percent.
With the dLAN® 200 AVsmart+, devolo supplies the best home network over the electrical wiring! Without any expertise, you can connect your network-compatible devices such as PC and Mac computers, game consoles, network printers or NAS hard drives to one another and to the Internet at a maximum speed of up to 200 Mbps. dLAN® does this wirelessly – over the entire household electrical wiring. This way, every power outlet becomes a network jack in no time! devolo's dLAN® adapters also combine easily and can be expanded again and again. An example: Have you bought a new IPTV set-top box (like T-Home) or a new laptop? Purchase another dLAN® adapter and your new network-compatible device is quickly and securely connected with the Internet and the other devices in your home LAN.
There are many good reasons for you to reach for devolo's dLAN® 200 AVsmart+: With the latest dLAN® generation, it not only offers maximum data transmission, its outstanding range also makes it possible to bridge cable lengths of 300 metres. This is confirmed by not only market leader devolo's German development, but also tests in numerous leading trade journals! The dLAN® screen status display developed in-house by devolo shows the connection status with other dLAN® adapters; the encryption button enables secure operation. But the dLAN® 200 AVsmart+ still has more to offer: The integrated socket ensures that no electrical outlet goes to waste. Furthermore, the integrated mains filter ensures best possible transmission. A clean environment was also in mind during the development. The dLAN® adapter consists largely of recyclable materials. But that's not all: Thanks to the patented power-saving technology Dynamic PowerSave, the dLAN® 200 AVsmart+ reduces its energy consumption automatically by over 60 percent.
Only £65.91 inc VAT.
ORDER NOW
PRODUCT FEATURES:
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
