- 27 Jun 2008
Hello
Turned the res up to 2048 on Return to Castle Wolfenstein and the game has stopped loading with this error message page. Its only effecting this game and i cannot get back in to lower the res. Also tried uninstalling and then re-installing
Any idea? The main error is "could not load OpenGL subsystem"
Wolf 1.0.0 win-x86 Nov 13 2001
----- FS_Startup -----
Current search path:
C:\PROGRA~1\RETURN~1\main\sp_pak2.pk3 (232 files)
C:\PROGRA~1\RETURN~1\main\sp_pak1.pk3 (1342 files)
C:\PROGRA~1\RETURN~1\main\pak0.pk3 (4775 files)
C:\PROGRA~1\RETURN~1/main
6349 files in pk3 files
execing default.cfg
couldn't exec language.cfg
execing wolfconfig.cfg
execing autoexec.cfg
Hunk_Clear: reset the hunk ok
...detecting CPU, found AMD w/ 3DNow!
Bypassing CD checks
----- Client Initialization -----
Cmd_AddCommand: map_restart already defined
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\system32\opengl32.dll' ): succeeded
...setting mode 10: 2048 1536 FS
...using colorsbits of 32
...calling CDS: failed, bad mode
...trying next higher resolution: failed, bad mode
...restoring display settings
...registered window class
...created window@3,22 (2054x1568)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 0 )
...101 PFDs found
...hardware acceleration found
...PIXELFORMAT 7 selected
...creating GL context: succeeded
...making context current: succeeded
...WARNING: fullscreen unavailable in this mode
...using colorsbits of 16
...window already present, CreateWindowEx skipped
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
RE_Shutdown( 1 )
GLW_StartOpenGL() - could not load OpenGL subsystem
Any idea? The main error is "could not load OpenGL subsystem"Wolf 1.0.0 win-x86 Nov 13 2001
execing default.cfg
Bypassing CD checks
----- R_Init -----
...initializing QGL
...101 PFDs found
...initializing QGL
RE_Shutdown( 1 )
