Turning a TFT into a standalone TV?
12 Dec 2006
Is there a gizmo that will allow you to use a PC TFT as a TV without using a computer? I know there'll be issue with PAL and PC resolutions but, I've a spare 17" TFT and it seems a shame not to use it for something, instead of selling it for a pittance.
Hi,
there are external tv tuners that can be used just for this and they're not very expensive either you should get one for around 35 pounds if you look around.. OcUK don't seem to have them at the moment though
I think he's looking for a freeview box with a VGA output on it? One does exist, its quite expensive though (£60ish I think).
P.S Sorry, I don't remember its name, and I don't think OcUK stock it.
Edit: £60 is off the mark, its more like £100 :P.
AVerMedia Digital Set-Top Box (DVB-T STB3)
Super sleek, portable AVerMedia TVBox STB3 transforms your LCD monitor into a Digital TV and plug-n-play multimedia entertainment station, with or without using a PC. Cutting edge Progressive Scan technology and 3D-Motion Adaptive De-Interlace give sharper images while you enjoy full-screen SXGA high-resolution display (up to 1280 x 1024). Work on your PC and watch TV simultaneously with the convenient Picture-in-Picture function! With AVerMedia TV Box STB3, compatible with VGA input LCD/CRT/Plasma/Projection displays, watch TV, movies, and play video games in style!
* Supports Resolution up to 1280 x 1024 (SXGA)
* Picture-in-Picture (PIP) Function (PIP See-Through Translucent Mode) Supports up to 1280 x 1024
* Progressive Scan Output
* 3D Motion Adaptive De-Interlace
* Supports all LCD/CRT/Plasma/Projection Displays with VGA Inputs
* All Frequency/All Channel Scan with Channel Memorizing Function
* Plug-n-Play, No Software or Drivers Required, Applicable to all O/S
* User Friendly OSD (On Screen Display) to Control Functions
* Fully Functional Infrared Remote Control
* Sleep Timer
ChoÞÞer said:
if your pc can support it.. have duals?
What? I want something I can use without a PC attached.
Xon said:
Hi,
I'm not seeing them for that cheap! But yeah I think an external Tuner looks like what I'm thinking of.
Not specifically looking for freeview.
M0t0r0la said:
AVerMedia Digital Set-Top Box (DVB-T STB3)...
Something like that yeah. TBH all I need is one with a Scart to VGA. I only intend putting a DVD player through it. Tuner and anything else is a bonus.
