Turtle Beach Xbox 360 headsets
19 Mar 2011
Glasgow
Can anyone recommend a good set?
My son has out a pair on his Christmas list ;) but I don't know which ones to get as there are so many options.
I am looking to spend upto £75 and would prefer a wired connection.
Can anyone give suggestions? Cheers
I have th P11's and altho not the best spec they work perfectly for me.
they are comfortable and the mic works well.
I have heard things with them on that i havnt heard without them. also i can't hear the kids on the ipad so double win
I have the X12 set form when i played on Xbox. Still performs well after two years. never had a problem with them. They were £45 when I got them, not too sure on the price now.
X12's are still probably the best wired TB headset available for the 360, or if you want a set that can be used on both 360 and ps3 you could try the PX22.
You could consider adding a DSS/DSS2 with the X12 so it uses the optical out and adds virtual surround sound (or buy it as a package, listed as the DX12), should still be within budget but it depends if the sellers have stock.
