TV above log burner?
19 Dec 2010
The south
As the title says really. Have purchased our first house, that doesnt have many options for TV layout. One of which is putting our TV (42" LCD that we have been gifted!) above the log burner.
Assuming the chimney breast is substantial enough to support it, would there be any issues? I cant imagine (but will check) that it gets too hot.
Not sure what what size bolts/screws your going to use but remember there could be a metal flu behind the chimney breast.
Thanks for pointing that out. I guess assuming all is well with the physical positioning of the TV, I was wondering from a heat point of view, wondering if anyone had done the same.
I think you might kiss your gift goodbye putting it there.
Folk go OTT about fixings.
Unless you've got a false chimney breast constructed from non-combustible materials (e.g. metal frame + fireboard/vermiculite to meet Part J of Building Regs) then chances are you're going to be fixing in to brick or block or stone of some description. Bricks are 100~110mm deep. Concrete block and aerated block is 100mm deep. This means there's at least 100mm of some kind of solid building material (brick or block) separating you and your drill bit from the chimney liner.
On top of the brick/block there's the surface finish. It could be plaster or dot-n-dab. Allowing for the thickness of the top surface finish, all you need is a maximum of 50mm penetration in to the brick/block for a fixing. Fixed the right way, those little red wall plugs that are 30mm long will hold a staggering 50~100 kg a piece. "Fixing right" means getting the correct diameter hole drilled (5.5~6mm masonry bit) and no more than 40mm penetration of the brick/block. Ensuring the fixing isn't in the mortar bed between bricks or at the edge of a brick - that's why you use multiple fixing points - and finished with the correct size screw diameter/gauge (3.5/4.5mm - No. 6/8). Fix your bracket with 8 screws and even if you only get four solid fixings you'll still have 200 kg of load capacity. You could hold two chubby blokes off that. A telly will be no problem.
Here's a guy testing red wall plugs https://www.youtube.com/watch?v=0Lx7uaboPdw
Someone would have to be a complete knucklehead to drill all the way through the block work and damage the liner. Use some tape on the drill bit as a depth marker.
If there is a problem with a telly over a log burner then it's dust. LCD screens aren't sealed. The convected air will carry dist and smoke particles in to and over the inside layers of the LCD screen.
Heat is a secondary issue. A mantle can deflect a bit of it. It just depends really on how hard the fire is driven.
Not the mounting thats an issue. Our chimney breast above our modest log burner gets very hot after a few hours burning. I wouldn't want cables and a tv there. Seems like a bad idea.
Yeah, the brickwork heats up a fair bit after some hours. Probably not hit enough for major problems , but possibly an issue .
Main problem with fireplace mounted TV is that it's just too high for comfortable watching. And looks a bit naff.
Apologies all, I completely forgot that I had posted this. Having moved in now, we have decided having the TV above the burner doesn't go with the charm of the cottage so will be sticking it in the corner!
