TV and sky
30 Oct 2005
Hope i am in the right forum.
I want to buy a flatscreen tv for the bedroom, at the momment I have an old style tv with a coax connection at the back so I can plug in the sky cable from the main tv in the living room.
My question is if i buy a new LCD tv will I still be able to do that?
the spec =
Auto Install Yes
Brand Technika
Colour Black
Component Input 1 YPbPr
Contrast Ratio 300:1
Depth in cm 147
Digital Tuner Yes
Fast Text Yes
Features of Product Image close to nature (ICN). Digital noise reduction (DNR). Digital comb filter
Flat Screen Yes
Front AV Sockets 1 back AV Socket
HD Ready Yes
HDMI Sockets 1
Headphone Socket Yes
Height in cm 330
Optical Out No
Parental Lock Yes
PC Input VGA
Picture Frequency 50Hz
Product Depth 14.7 cm
Product Height 33 cm
Product Width 38.1 cm
Remote Control Yes
Resolution 1280*800
SCART Sockets 1
Screen Type Wide LCD
Screensize 15.4"
Sleep Timer Yes
Sound Quality Nicam
Table Stand Included Yes
Teletext Yes
TV and VCR or DVD Combi TV/DVD Combi
VESA Yes
Visible Screen Size 15.4"
Wall Mountable Yes
Weight in KG 2.81
Width in cm 381
thx...rob
Didn't know that, what do they have instead (is that a stupid question) ex-TV salesman here, interested to know.
I haven't come across a TV that doesn't have a UHF tuner (perhaps the Panasonic plasma with Freesat but I think that has a UHF tuner too?!).
More and more TV's are doing away with the analogue tuner which is what you need to connect the Sky RF2 output up to your TV.
Thanks' for the replys guys, so if this TV does not have a analogue tuner connection point is ther such a thing as a converter so I can still use sky upstairs for the footy?
